Christopher
- Jun 26, 2025
- Prepare Your Information: Before you call, make sure you have all relevant information ready, such as your Ledger device model, firmware version, and any error messages you're encountering.
- Dial the Number: Call
+1 (833) 534-2431
to connect with Ledger's support team.
- Follow the Prompts: You may be greeted by an automated system. Follow the prompts to reach the appropriate support department or a representative.
- Explain Your Issue: Once connected with a support representative, clearly explain the problem you're facing or the question you have.
- Follow Instructions: Listen carefully to the instructions provided by the support representative and follow any steps they give you to resolve your issue.
