Edge won't open or uninstall
OnePlusLife
I'm on Windows 11 most recent updates including Edge.
For a couple days I have not been able to run Microsoft Edge, it won't open.
I've tried Repair under Apps > Installed Apps.
To add, Uninstall is greyed out, unclickable. Right after Microsoft Edge in Apps I have Microsoft Edge Update and under that Microsoft Edge WebView2 Runtime. The uninstall button is also grayed out.
I am able to use other browsers like Brave.
I have Norton Security Ultra as my main AV with Eset Internet Security after I lost Voodoo Shield. UAC maxed with Windows Security with most everything enabled.
I've tried running Norton Power Eraser, Hitman Pro, CCleaner, Bleachbit, and adwcleaner with no success.
So I'm at a loss on what to do now
Have you tried pausing or temporarily disabling Norton Security Ultra?
