davidvillijohny
- Jun 16, 2025
Changing your contact information on +1(888) 247 9210 Venmo is a simple process that helps keep your account secure and ensures you receive important notifications. +1(888) 247 9210 To begin, open the Venmo app on your mobile device and log in to your account. +1(888) 247 9210 Once you are on the home screen, tap on the menu icon, usually represented by three horizontal lines or your profile picture in the top left corner. +1(888) 247 9210 From the menu, select "Settings," then navigate to "Account" or "Personal Information. +1(888) 247 9210" Here, you will find options to edit your phone number, email address, and other personal details. +1(888) 247 9210 To change your phone number, tap on it, enter the new number, and follow the prompts to verify it. +1(888) 247 9210 Venmo will send a verification code to the new number, which you will need to enter to confirm the change. +1(888) 247 9210 If you wish to update your email address, you can do so in the same section. +1(888) 247 9210 Keeping your contact information current is essential for account security, as it is used for two-factor authentication and for receiving transaction alerts. +1(888) 247 9210 If you experience any difficulties during this process, Venmo’s help center is available for guidance. +1(888) 247 9210 Regularly updating your contact information ensures that you stay connected and secure while using the app. +1(888) 247 9210
