How to Fix Incorrect Payroll Taxes in QuickBooks Desktop Call 18046350107
babatillu
QuickBooks Desktop – Call 18046350107
📞 Need immediate help? Call 18046350107 and get expert payroll support today.
🚨 Signs Your Payroll Taxes Are Incorrect​
  • Net pay doesn’t match expected amounts
  • Tax amounts (Social Security, Medicare, FUTA, SUTA) seem too low or too high
  • Employee exemptions or tax statuses not applied correctly
  • Payroll liabilities showing negative or unusual balances
  • W-2 or 941 reports don’t match payroll records
🛠 Step-by-Step Fix for Incorrect Payroll Taxes in QuickBooks Desktop​
✅ 1. Update Payroll Tax Tables
Go to:
  • Employees > Get Payroll Updates
  • Check Download Entire Update, then click Update
Outdated tax tables are one of the most common causes of calculation errors.
✅ 2. Verify Employee Payroll Info
  • Go to Employee Center
  • Double-click the affected employee
  • Under Payroll Info, click the Taxes button
  • Review Federal & State tax settings, exemptions, and filing status
✅ 3. Check Payroll Item Setup
  • Go to Lists > Payroll Item List
  • Edit each tax item and compare with your payroll tax rate or thresholds
  • Watch for:
    • Duplicate items
    • Incorrect percentages
    • Inactive or outdated items
✅ 4. Run the Payroll Checkup Tool
  • Navigate to:
    Employees > My Payroll Service > Run Payroll Checkup
  • This built-in tool scans for common tax setup errors and recommends fixes
✅ 5. Recalculate Payroll Tax on Specific Paychecks
  • Open the affected paycheck
  • Remove the tax item
  • Re-enter it manually to force QuickBooks to recalculate
📞 Get Expert Help Now: Call 18046350107​
If these fixes seem overwhelming—or you’re dealing with a multi-paycheck or multi-state payroll issue—don’t guess.
Call 18046350107 and talk to a QuickBooks-certified payroll expert. We’ll help you:
  • Correct prior payroll entries
  • Update tax settings across multiple employees
  • Balance payroll liabilities and fix tax forms
  • Avoid IRS or state tax penalties
🧾 Bonus: Stay Payroll-Compliant Year-Round​
  • Backup your company file weekly
  • Run Payroll Checkup each quarter
  • Set calendar reminders for payroll tax updates
  • Keep your QuickBooks and payroll subscription current
