KB5037591 Causing BSOD
I installed this update yesterday on my P3 Ultra machine. This morning, I experienced repeated BSODs. Although the update seemed successful after selecting "update and shutdown," I had to roll back using the recovery options to a date (10th of May), which did not resolve the issue. I then uninstalled an update via recovery options (unspecified during the process), which removed KB5037591 and reverted to KB5036620. Since then, my computer has been stable with no BSODs.
My question is: Is there anything in this update that could be causing these issues? Lenovo is also investigating, but I wanted to see if anyone else has faced similar problems or reported them to Microsoft, as I couldn't find a way to do so. Additionally, I'm puzzled why the rollback didn't work, yet uninstalling the update did. I've paused updates for 5 weeks and am concerned about what will happen when these updates are reinstalled.
Use Media Creation Tool with original latest ISO and reinstall Windows (Not from Boot-up) but install Windows from current Windows itself and select Keep My Files, Apps & Settings ..
So, after all that Hate and Discontent, have you learned your lesson, concerning Windows Updates?
Probably not, at least it would appear so, from your post.
If you'll take the time, to read through the posts on this forum, about BSOD's and other problems post Update, you see that most of the problems being reported are directly related to screwed up Windows Updates.
I eliminated that problem for myself and my several hundred customers, by just Shutting OFF MS Updates.
And, I've never had a Crash or BSOD since then.
Why are you willing to subject yourself to continuing problems, from Microsoft?
I very seldom respond to problems involving an MS Update, because the answer to the question is just so Obvious.
If something that you're doing Hurts You, then for Goodness Sakes, STOP DOING IT!
Finis
