Lines on taskbar
charlestan
Hi. I am using a ASUS laptop with i3-8xxx Intel.
There have been many lines on the taskbar of Windows 11.
Thank you.
This is a sure sign that your display is about to go south. those lines are typical for a LCD-screen failure. Only option you have is to replace the screen.
quote: "ASUS laptop with i3-8xxx Intel." Are you running Windows 11 through a hack? That can also cause problems with some computers -
does that happens on every windows opened? try "auto hide taskbar" and open some window to see if the problem persists, if yes .. then your LCD might be the issue .. :)
