Retail – Can be moved to another device (must uninstall from the old one first).
OEM – Tied to the original hardware, can’t be transferred.
Volume – Usually for organizations, with their own rules.
You can check your license type by opening any Office app → File → Account → look under Product Information
Microsoft requires you to remove Office from your old computer before installing it on a new one:
Windows: Start → Settings → Apps → Apps & features → Microsoft Office XXXX → Uninstall.
Download and install MS Office into new computer
Product Key Finder Tools - Tools like EaseUS Key Finder or NirSoft's ProduKey can help you locate the product key stored in the Windows Registry. These tools may not work for all versions of Office, particularly newer ones associated with Microsoft 365 accounts.
For Office 2019 and later, particularly those associated with Microsoft 365, the product key is often linked to your Microsoft account and may not be needed for reinstallation or activation after logging in.
Remember - You can only transfer a one‑time purchase license once every 90 days (unless your old device failed)
