Reinstall win 11 Pro
Denny
I built a computer and installed Win 11 Pro. Years later I gave the computer to a relative and I want to reinstall the Win 11 Pro and remove all my info. If I need the Win 11 product key - how do I find it. I tried using Command Prompt steps twice - nothing, using PowerShell steps twice - nothing, Registry Editor once. still nothing.
Do I even need the Product key. Won't it install the key on its own when asked for. I will be using a USB with Win 11 Media Creation tool on it.
Bastet
You can try using showkey plus from the MS App Store which may show the key but unless the key is retails it’s tied to the Motherboard & can’t be used on another PC.
If you’re installing on the same PC then once the you/the new owner signs in it’ll activate automatically. On setup when it asks for the key just skip this.
