W11 Task scheduler question
StephanP
How can I setup a W11 Task scheduler that does the following:
- Trigger: two apps becoming active (Windows Terminal and CEmu graphic calculator emulator)
- Action: Close the Terminal window
Here's a good article about setting automated tasks, but it's focussed at time based scheduled tasks I cannot find what I should do for above mentioned trigger and action. Any help is welcome.
Not sure, if I fully understand what you want.
Just a guess (I don't work with Terminal, but with cmd prompt). What happens, if you link the Terminal trigger to a shortcut to Terminal (not to Terminal.exe directly) and add in "Properties" of the shortcut "-exit" after ... .exe?
