Winaero Tweaker 1.64
Winaero Tweaker is an an all-in-one customization utility that helps you to tweak Windows in just a few simple clicks. The program includes tweaks for every version of operating system from Windows 7 to Windows 11. Winaero Tweaker automatically detects the version of Windows OS you’re running and shows tweaks and customization options accordingly. The software can be installed as a portable app so you can take it with you as you move from one computer to another.
Here's a partial features list:
  • Information - View information about your PC hardware and OS.​
  • Aero Colors - Change all Windows Aero settings including those which can't be changed with Control Panel.​
  • Aero Lite - Activate the hidden Aero Lite theme.​
  • Alt+Tab Appearance - Change hidden secret options of the Alt+Tab dialog.​
  • Colored Title Bars - Enable colors for window title bars in Windows 10.​
  • Dark Color Scheme - Here you can enable the dark color scheme for Windows 10 system settings and apps.​
  • Inactive Title Bars Color - Change the color of inactive title bars in Windows 10.​
  • Disable Aero Shake - Disable or enable the Aero Shake feature.​
  • Disable Driver Updates - Turn off driver updates in Windows Update.​
  • Disable Web Search - Disable Web Search in taskbar and Cortana in Windows 10.​
  • Disable Action Center - Disable or enable the Action Center feature in Windows 10.​
  • Disable Live Tiles - Disable Live Tiles all at once for Universal(Metro) apps.​
  • Activate Windows Photo Viewer - Activate Windows Photo Viewer in Windows 10.​
  • Auto-update Store apps - Disable or enable auto-update of Store apps in Windows 10.​
  • Disable Cortana - Disable Cortana in Windows 10.​
  • Disable Windows Defender - Disable Windows Defender in Windows 10.​
  • Microsoft Edge Download Folder - Change the default download folder in Microsoft Edge.​
  • Stop Unwanted Apps - Stop unwanted apps Windows installs automatically.​
  • Windows Defender Tray Icon - Show or hide Windows Defender tray icon.​
  • App Switcher Hover Timeout - Change the App Switcher hover timeout delay.​
  • Charms Bar Hover Timeout - Change the Charms Bar hover timeout delay.​
  • Modern App Closing Options - Speed up closing time of Metro apps for mouse and touch.​
  • Start Screen Power Button - Show or hide the Power button on the Start screen.​
  • Disable Telemetry - Prevent Windows 10 from spying on you.​
  • ... and many more.​
Winaero Tweaker 16.4 Key Changes
This release focuses on usability, HiDPI support, and removing broken or outdated tweaks, while maintaining compatibility with recent Windows 11 updates.
New Features
  • Disable Recommended in Start: Users can now turn off the Recommended section in the Windows 11 Start menu.​
  • Remove “Ask Copilot”: Added an option to remove the Ask Copilot context menu via Context Menu > Remove Default Entries.​
  • Custom Drive Icons: Users can set custom icons for any drive letter and define a new default icon for hard drives.​
  • Dark Theme Support: Winaero Tweaker now supports dark mode on Windows 10/11 and selectable themes on Windows 7/8.​
  • Font & Icon Scaling: Fixed font scaling for HiDPI screens and added a manual font size option; left-panel icons now appear crisp.​
Fixes & Improvements
  • Correct reporting and functionality for Disable Defender, Disable Copilot, and Tamper Protection toggles.​
  • Resolved multiple registry-related and UI bugs, including Inactive Titlebar Color, Disable Lock Screen, and XMouse options.​
  • Updated File Explorer tweaks: hiding Home folder, disabling Ribbon, and fixing desktop context menu options (Copilot, Snipping Tool, Settings).​
  • Removed obsolete tweaks that no longer work on Windows 11 24H2/25H2, including Cortana-related options.​
Known Issues / Upcoming Changes
  • Some toolbar and info page icons still appear blurry.​
  • “Disable Windows Update” page will soon allow method selection.​
  • Classic taskbar customization is largely unsupported in Windows 11 25H2+, pending possible future fixes.​
Download page: Winaero Tweaker 1.64 | 5.3 MB (Freeware)
View: Winaero Tweaker Home Page | Screenshot
