1920x1200 Resolution no longer available
thomasarm
I have a new Acer Predator Helios 300 gaming laptop with an nvidia 3060 graphics card and things were going fine until I was troubleshooting stuttering video while casting my screen to my TV. It had helped in the past to lower the resolution, and then it would revert back when I disconnected from the external screen. However, this time the resolution is stuck on 1920x1080 and things look stretched. I am convinced that the old resolution was 1920x1200, but I guess I could be mistaken. However, I am absolutely certain that things don't look right on my monitor. I've tried to update the drivers, and I even reset the computer but nothing has helped. Any ideas?
Did you change something in "Settings\System\Screen\Scalings" ? Reset everything to 100% (may be you need to log out and in, but Windows will tell you).
Otherwise there is a nice little freeware from 12Noon, called "Display changer" with which you could at least try to find out (by testing) what was likely your previous resolution.
hope you can use the manufacturer supplied driver to "force" install, dont ue the Microsoft supplied drivers as stock :)
