Aero Glass Incompatibility Issue
helpme
Hello,
I really liked the aero glass in windows 7 and wanted to try it. I downloaded aero glass but it was incompatible because I use windows 11 but it was for windows 8. I deleted the file because it was incompatible but now every time I boot up my computer, it gives me a "aero glass is incompatible" type popup message. And it repeats every 30 minutes which is really annoying.
How do I get rid of this popup?
Thank you
Excursius
could it perhaps be that it attempts to startup ? , you can check in settings under startup or
Windows+r
shell:startup or Shell:commonstartup
helpme
Windows+r
it doesn't show aero glass as a startup app
its not even there
Grab this
Take a moment to read that page to get an idea of how to use it then unzip it and go ahead. right click it and run it (Autoruns64.exe) not (autorunsc64.exe OR Autoruns64a.exe) as administrator. Click the Options menu item and make sure the top three are checked and hit the refresh/rescan (Green Arrow circle).
Don't get overwhelmed by the Everything tab. Used the individual tabs pay attention to the Logon, Explorer, Scheduled Tasks, Services, and Drivers Tabs.
See if you find anything there that might suggest something associated with "Aero Glass".
IF the Entry column doesn't do it, pay attention to the Publisher column and see if that might help.
