Crashing explorer
Ian
I've not had Explorer crash yet. Do you get any errors showing in the event logs?
Richee911
Faulting application name: explorer.exe, version: 10.0.22000.51, time stamp: 0xa0f1a2fc
Faulting module name: ExplorerExtensions.dll, version: 421.16300.0.0, time stamp: 0x60c47247
Exception code: 0xc000027b
Fault offset: 0x000000000004fe9b
Faulting process id: 0x1164
Faulting application start time: 0x01d76e9789edebc0
Faulting application path: C:\WINDOWS\explorer.exe
Faulting module path: C:\Windows\SystemApps\MicrosoftWindows.Client.CBS_cw5n1h2txyewy\ExplorerExtensions.dll
Report Id: 0009aec4-4579-4f99-9cb5-17732c03755c
Faulting package full name:
Faulting package-relative application ID:
This or wdym?
Ian
Yep, that's the one.
It looks like some sort of plugin is causing the issue - do you have some backup software or file sync software installed?
Richee911
Backup and sync from google and also Dropbox and OneDrive if these are backup apps.
Ian
Can you try disabling them for now (maybe OneDrive is ok to leave) and see if that stops it? If so, try adding them back one by one.
Ian
Please do let us know how it goes, as it would be good to be able to identify which software is incompatible for now.
Richee911
I think it didn't work. Here's the log:
Faulting process id: 0x1248
Faulting application start time: 0x01d76e97df6c8fe2
Report Id: 0c2dbfdf-f130-4cd3-b003-c09636b2f5ae
Richee911
Sorry, idk, there's more errors, I'm confused, but explorer is still crashing.
Ian
The only other link I can see here is a problem with the software keyboard, as that module path matches. Are you using this on a tablet PC?
Rerih02
I solved it by unplug the power line on laptop and switching out ACPI battery in Settings. But this is bad solution - now I cannot see my battery status. Sucks.
Ian
Oh wow, that's an interesting solution - I didn't expect that would have been the cause. Thanks for reporting this @Rerih02, I hope this works for @Richee911 too.
Ian
Looks like the latest update has fixed an issue with explorer.exe crashing, related to a 100% battery charge - so hopefully this solved the problem :).
alexh
I just had this issue and fixed it by changing my time zone back to -8 for pacific time. Tried every other solution but the time zone ended up being the only thing that fixed it.
