I have Questions about a new build for Win 11
Edwrd10
What is Optane memory and how does it work and do I need it? I am looking at an ASUS Z590-E Motherboard. It has support for Optane Memory. I do not know anything about Optane memory. I haven't built a PC in 3 years, so I have to catch up.
Me either, although I caught some mention of it, while I was researching a recent new build that I constructed for Windows 11.
So I did a little more research and my basic understanding is that it works as a non-volatile cache area where data is stored, consisting of information that it determines based on its' own algorithm, your systems uses with some frequency (startup files and the like).
I looked at an article from How To Geek (one of my trusted resources)...
BUT then I noticed that it was from 2017. Thinking that it must have evolve to a more robust resource over 4 years or so
SO I read this something a bit more recent
Turns out it hasn't evolved all that much, at least not so far, on the consumer side of things.
Basically, you can have either a 16 or 32 Gig cache that is apparently much faster with respect to access times
Which will as I understand will benefit performance when it comes to System start times and I suspect for those gamers amongst us better in-game response times.
SO...
IF you're considering building a high end, screaming rocket you'd want to consider adding it to your build.
BUT...
If your reading emails, browsing the web and social media you could probably safely skip it.
