Safe to disconnect USB no longer enabled
Mickey52
something changed, when I try to eject a drive, it does not say it's safe too.
Bastet
Is quiet hours &/or Focus Assist turned on? If so (especially Focus Assist) then this prevents the popup notification from showing. I recommend turning these off & seeing if this is the cause.
Mickey52
I turned focus assistance off it was on. Tonight, backing up a program to eternal drive will let you know if it fixed issue.
Thank you for your help and Happy New year
Mickey52
just backed up a money manager program weekly back up it worked, thank you I have on One note a file for Win10 fixes and Win11 fixes I will add that one to my notes.
Mickey52
Here is another one for you. Until Win 11 spelled and grammar check I would correct with right mouse key now I have to with left. I tried changing primary key to right but that messes more then it fixes. To close a window or a program you have to use the right key.
is there a way to reset spell check but nothing else?
Bastet
Spellcheck on my PC uses the left mouse button (I click on the word & allows me to choose the correct spelling) & did so on Windows 10.
Check to see if all are enabled here:
Start > Settings > Devices > Typing
