Fingerprint scanner on Dell G5 5500 sometimes doesn't work?
james_uk
Hi, occasionally my laptop will start up and i will place my finger on the fingerprint reader (power button) and nothing happens, it doesn't even incorrect finger etc.
It's definitely clean though.
If I then restart the laptop again, it's always then fine and works that time.
Does this just sometimes happen?
The reader is made by goodix.
The driver for this seems very old, but there doesn't seem to be any newer ones. Dated 2019.
Regards
James
Regards
James
Wash your hang, fingers and wipe with dry cloth and try again, this trick works .. :D
