Micro sd card not being detected
Xellerate
My micro sd card is not being detected in disk part or format disks program, it detects the driver for that reader, but not the sd card itself.
Bastet
If it isn’t being detected in diskpart then it is a good indication the card has failed.
Does it show under disk management?
Do other SD cards show when inserted?
Xellerate
It doesnt show in diskpart, but when I usb sd card reader it shows the card, but for some reason, it just doesnt show it with the internal sd card reader
Xellerate
I'm thinking that if I flash windows 10 then upgrade to windows 11 maybe it will keep some files and drivers and their configuration
Bastet
Do other SD cards show when inserted into the internal SD card reader?
Is the internal SD card reader showing under device management?
Xellerate
No other sd card shows up, not even the one in my phone, I suspect it to either be a driver issue or a windows issue, but it's most likely a driver issue, problem I've got the latest driver for it
Bastet
Does the internal SD card reader show within device management? If not then check further under view>show hidden devices. If it does not appear under any of these then the internal card reader has failed.
Reinstalling or upgrading Windows will not fix it if this is the case.
Xellerate
It shows the sd card reader, sometimes, I have to take it out and put it in again, then it detects it but it doesnt want to load the micro sd card that's on it, those ad card work perfectly on other devices
Bastet
I Would say the internal card reader is faulty & failing. Either replace it or continue using the external card reader.
If you can get device manager to show the reader then you could reinstall an older driver.
You might have to reinstall the driver via the entry under show hidden devices.
Right click device.
Choose update driver.
Choose ‘browse my computer for drivers’.
Choose ‘let me pick from a list of available drivers on my computer’.
Choose the compatible hardware from the list, then choose next.
Choose one of the older drivers from the list shown, then click next.
This will then reinstall the driver.
Xellerate
Right click device.
It could also be because its lenovo, so I'm trying to install the os through their usb recovery software, their could be a chance that I'm missing some drivers that lenovo ships with their laptops
Xellerate
So I just installed their version of windows 10, the sd card shows up, I'm now doing an upgrade to windows 11, maybe i was missing some specific drivers
Bastet
Thanks for the update. Hopefully the Win 11 upgrade goes smoothly.
Yes that is possible. However you should’ve been able to install the correct drivers from the PC manufacturer’s website.
Keep us updated.
Bastet
Great news. I would recommend that you now use disk imaging software like Macrium Reflect in case of future problems.
