Webcam problem
m681
Translated by Google, in my first message I said that I moved the mouse with my head, for this I need the webcam, the laptop comes with the integrated webcam, my problem is that sometimes the image freezes and starts to turn upside down and back up continuously, and I can't move the mouse, why and how do I solve it? Thank you.
Gestural controls typically do not use a single standard webcam; crude webcam gesture controls are probably possible, but they would be far more trouble than they are worth, as a single camera has no depth perception. Typically gesture control software requires hardware designed for the task and what make is your laptop and does the manufacturer gives any manual reference that your webcam supports gestures?​
